How do I configure a PIN (Pulse Input) function block for shaft RPM.
Phil L
3 Jul 2023 2:10 PM
laurent maurer
26 Jun 2023 5:20 PM
Use a screen 55 inch
TPatterson
19 Jun 2023 6:31 PM
Martin v. Bergeijk
19 Jun 2023 3:34 PM
DeltaV Simulate
ElectroTech
19 Jun 2023 2:08 PM
DI as Pulse Input (PIN) for belt speed
deriving a flow rate from a pulsed input - is the Pulsed input function block the right block for this application?
Timed Pulse Function Block
Turbine Flowmeter Pulse Input to DeltaV
How do I wire pulse device to a Series 2 Multifunction I/O Card installed in backplane as card #5 with an MDPlus controller.
The pulse generator is a CAT magnetic speed pick up generating up to 2500HZ, voltage of 12Vac across its terminals. Do I wire this directly to the multifunction card via an SD32 barrier just like that? I have one speed sensor wired this way to terminals 25/26 of the I/O card but it seems not to record any frequency at the DCS. Please help.
