How do I configure a PIN (Pulse Input) function block for shaft RPM.
dave_marshall
13 May 2024 5:28 PM
List of Logged in Users on HMI
TPatterson
9 May 2024 6:47 PM
Enable and disable alarms on a workstation based on which user is logged in
Mohd Ramdhan Ramli
6 May 2024 12:22 AM
DeltaV gave Windows error "Not enough storage is available to process this command"
gbilly
3 May 2024 4:53 PM
Troubleshoot and configure Modbus
Valentin Borsu
1 May 2024 5:31 AM
DI as Pulse Input (PIN) for belt speed
deriving a flow rate from a pulsed input - is the Pulsed input function block the right block for this application?
Timed Pulse Function Block
Turbine Flowmeter Pulse Input to DeltaV
How do I wire pulse device to a Series 2 Multifunction I/O Card installed in backplane as card #5 with an MDPlus controller.
The pulse generator is a CAT magnetic speed pick up generating up to 2500HZ, voltage of 12Vac across its terminals. Do I wire this directly to the multifunction card via an SD32 barrier just like that? I have one speed sensor wired this way to terminals 25/26 of the I/O card but it seems not to record any frequency at the DCS. Please help.
