How should a PIN (Pulse Input) function block be configured to show shaft sped in RPM. The speed pickup gear on the shaft has 72 teeth (1 RPM) and maximum speed will be 1500 RPM.
There are no examples for this application in BOL and configuration notes are skimpy. Pulse signal input is coming from a Charm Discrete Input (w/ IS DI NAMUR CHARM). CHARM is set to Pulse Count Input and High Frequency is enabled.
What should be the PIN parameter values for PULSE_VAL and OUT_SCALE?
Has anyone done this before, have a working example?
