How do I configure a PIN (Pulse Input) function block for shaft RPM.
Jimmy Lee
9 Jun 2023 1:11 PM
ElectroTech
5 Jun 2023 12:33 AM
Invalid String
29 May 2023 2:13 PM
Shaswat Raj
27 May 2023 9:18 AM
PK100 Not able to communicate over Ethernet/IP on different assembly instance other than 101,100,102
Carson French
24 May 2023 1:04 PM
DI as Pulse Input (PIN) for belt speed
deriving a flow rate from a pulsed input - is the Pulsed input function block the right block for this application?
Timed Pulse Function Block
Turbine Flowmeter Pulse Input to DeltaV
How do I wire pulse device to a Series 2 Multifunction I/O Card installed in backplane as card #5 with an MDPlus controller.
The pulse generator is a CAT magnetic speed pick up generating up to 2500HZ, voltage of 12Vac across its terminals. Do I wire this directly to the multifunction card via an SD32 barrier just like that? I have one speed sensor wired this way to terminals 25/26 of the I/O card but it seems not to record any frequency at the DCS. Please help.
