flow transmitter selection
Hello
I want to install flow transmitter in pipeline. The transmitter should sense the flow in pipe in both directions. Somebody can help me to select right transmitter type.
Best regard
Mohsen
  • Dear Mohsen,
    An Ultrasonic flowmeter is a bidirectional flowmeter and should able to measure flow in pipe for both direction,
    If you send me your specific requirement we should able support you further
    Regards
    Anand
  • Hi,
    There are several DP Flow technologies you could consider for bi-direcitonal flow.  These technologies include certain styles of the averaging pitot tube, venturi, and wedge meters.  Your application can help determine which technology is the best fit.  For example, if the application is steam and you are also concerned about permanent pressure loss, an averaging pitot tube is a good fit, or if the fluid is highly viscous/dirty, a wedge or venturi meter might offer a better solution.
    Hope that helps,
    Katie
  • In reply to Katie Hausman:
    Thanks, for your answers, I want to use it for crude oil measurement. I prefer Ultrasonic, because is maintenance free.if know any model number. please help me to select right one.
    best regards
    Mohsen
  • Hi Mohesn,
    We have not met - I am Bill Graber with Emerson.  I have worked with Emerson for 20 years across several flow technologies within our offering - including DP Flow, Coriolis, Magnetic and Vortex.  I would reccomend that you give us more details on your application, including the use of the measurement (is this custody transfer, monitoring, control, etc), what is the line size, fluid, pressure, temperature, estimated flow rates.  If you tell us these details, we will be able to guide you to a couple options for solutions that could meet your needs.
    Bill
  • In reply to BillGraber:
    Sorry Mohsen - I did not see your response before I sent mine.  Sounds like you have what you need and Anand will be able to help with the details.  If there is anything else you need, let us know.  Bill
    Thanks Bill.
    Hi Mohsen,
    For crude measurement either you can use Daniel Liquid USM model 3812 which is a 2 path meter or a 4 path meter.
    This is my:
    email : Anand.Kuppan@Emerson.com
    mobile no: +65 9183 6157
  • In reply to Anand Kuppan:
    Thanks for your valuable data; I will check the suggested model number.
    Thanks & regards
    Mohsen
  • In reply to Jim Cahill:
    Hi Mohsen,
    If you can send me your email address, I will provide more detail like brochures of this model numbers. it's big files
    my Email:mohsen.amouzadeh@gmail.com
