Can any body suggest the type of flow meter for the following applications
Flow meter for chilled water plant cooling tower
Flow meter for Chilled Water Plant Supply and Return lines
Flow meter for Chilled Water Plant De-coupler
Flow meter for SWRO(Sewage water reverse osmosis) Plant Potable Water Distribution
Flow meter for WWTP (Waste water treatment plant)Treated Sewage Effluent Distribution
Magmeters are commonly applied in these applications due their large rangeability, high accuracy, and negligible pressure drop. WWTPs are frequently required to meter their effluent and report total discharge to regulatory agencies. Rosemount E series magmeters have integral meter verification capability that allows users to verify the health of their magmeter system and provide the documentaion required by regulatory agencies. Plant utility managers often use Rosemount E series magmeters with the high accuracy option, 0.15% of rate, to optimize chiller performance.
Dear Mr Arshad,
Liquid Ultrasonic meter is being very ideal usage for all liquid application, Two path Daniel Liquid Ultrasonic meter model 3182 is widely use for water applications. The meter is fullbore, pigable with no pressure drop,
The two path LUSM 3812, has insitu field replaceble transducer. The meter with linearity of 0.3% and repeatibility of 0.1%
Anand Kuppan
