I have an APPs station that is licensed for 8000 points (Using only 5200) but when I try to add points in an a couple of external applications using Matrikon DM, I get an error to the effect that the OPC License limit has been exceeded. Using OPC Watchit I get the same error. These applications have been running for several years with no problems. I also have a couple of other applications which are OPC clients and there's no problem adding tags.This has only happened recently and there have been no software upgrades or Server issues. Anyone run across this in your travels?
In reply to Andre Dicaire:
