I had to reimage the Proplus yesterday because i did not have the proper installation media to begin with, I've been running off a generic server 2022 install until Guardian got their corrupt installation media updated. I used Live Administration to backup the database database and then I don't recall if i used Import or Restore after getting everything reinstalled. But, i got all the nodes updated and downloaded and workstation management in order. Thought I was good.
But now I cannot open faceplates on my graphics. I also cannot search for modules. I can search, but the modules don't show up. So, i don't have a way to open a faceplate. I decided to check on my GEMs and see if there was something weird with the Click interaction. When I opened the GEM in Studio.. it showed this..."READ ONLY Poet_AI_Transmitter GEM Class is referenced and cannot be edited without a Premium-level DeltaV Live engineering license."I'm sure this is not a licensing issue.. but I'm not sure how to make these not Read Only. There also seems to be a database sync issue, however my data is all showing up... so the graphic is showing everything correctly. I say database sync because the search tool isn't showing any modules at all.
DeltaV 15fp1.
We have seen the DeltaV live module issue frequently when adding new control modules. The workaround we have found is delete one of the module assignments from a controller, then re-assign and re-download the module. This has worked for us in every instance a new module, or set of modules, do not get populated in the Live database. Recently Guardian provided us with a SQL script to force the synchronization as well, however we haven't tried it at this point.
As far as the license issue, the premium performance license is require for class based GEM configuration.
In reply to Jesse Delanoy:
In reply to TreyB:
In reply to Andre Dicaire:
