Hi all
i need to make a Lantronix XP1001000-05R communicate to an EIOC. ( it comes embedded in a card with an extensometer device). The Xport communicates using: TCP/IP, UDP/IP, ARP, ICMP, SNMP, TFTP, Telnet, DHCP, BOOTP, HTTP, and AutoIP.
Has anybody manage to communicate with this device? ... or has an idea about how to do it?
This version is not Ethernet IP, you can connect to it using a PC and access to its config or read values but I need to input the value in the DCS.
https://www.lantronix.com/products/xport/#product-specifications
Thanks in advance.
