How does VIM and EIOC redundancy work on EtherNet/IP networks?
Let's assume the VIM and EIOC are originating both Class 1 and Class 2 EtherNet/IP communications. I would think the same configuration is automatically download or cross-loaded and running in both the primary and secondary EtherNet/IP (VIM/EIOC) scanner whereas only the data from the Primary EtherNet/IP scanner is being processed in the Controller.
I would assume you can manually force the Controller to switch over to use the Secondary EtherNet/IP scanner. Is there an automatic switchover option? What are the conditions that would cause it to failover to the secondary? Does is favor the primary and automatically switch back?
The VIM and EIOC redundancy has two EtherNet/IP interfaces. I can think of three network architectures as follows:
