I'm looking for the best solution so this is more of a discussion than a question. I have 3 sites that are remotely located and connected by an ethernet backhual or a dark fiber lease.. TBD.. nevermind that for now. Main site will have a Proplus serve as the CH. Each of the 3 sites will have a workstation. The concern is if or when we have an issue communicating between sites, the proplus would not be collecting all of the data at the other sites. So we have a gap. That's not good as there will be some critical instruments that must have records in order to get paid. My thought was to have each workstation with the built in 250 CH points collect a few of those critical points to have a store locally. SO, you'd have the main historian on the proplus. And then each workstation would collect a number of critical points.
Maybe there is a better way to go about this.
I'm looking for how i can set this up because it seems that CH wants to dictate by control strategy area. So, I wouldn't necessarily be able to separate data to the workstation historians by module. It seems to me i would have to create additional control strategies called... "SITE1_CRITICAL" and "SITE2_CRITICAL".. and assign the areas like that.
It's probably a workable solution. But, I would like to get some feedback. Thanks
In reply to Andre Dicaire:
