ProPlus Multiple Workstation
Hallo everyone,
Is it possible to work on one Proplus workstation project with multi user from seperate station on same multiproject.
Thanks for any answer
  • When you said 'multiproject' the answer became "no", except if you are willing to switch out active databases. Thus multiple projects cannot be accessed simultaneously. I assume you are doing development work for multiple sites/clients/systems and do not want their information to mingle within the same database, so your only option is multiple databases or separate DeltaV systems altogether. Even if you were to use multiple databases on the same server, since graphics and other things are in a shared directory, the likelihood that one project's graphics bleed into another's is almost impossible to stop from happening. You are better off building separate virtual machines in a hypervisor for each individual effort.
  • Hi
    I think it is possible .
    As one of client zentek singapur has contractor zenith technologies which has deltav server in nethrland and it will be accessed in singapur by using citrix . Where these contractor doing multiple projects are implemented and tested by using citrix and after that implemented at client site.
    Multtiple projects database can be swithover by changing active databases.
    Regards
    Prashant
