Looking for recommendations on what switches to use with our EIOC network.
looking to have switches in the MCC rooms where they would be close to VFDs and have switches in the field where they would be close to ASi Gateway and air manifolds.
I am thinking that the ones in the field might have to be mounted in an enclosure so that they would be protected from water and dust, but maybe there are other options out there?
Are people using managed or un-managed switches and why?
What switches have you found to be the easiest to setup/maintain?
Thanks for the suggestions.
