TL;DR: how do you exclude only one area from a batch operator interface if there is no pattern that matches all of the other areas for filtering?
Longer: I have four AREAs with batch operation that all tie to a Batch Operator Interface in a control room. I am adding a fifth AREA to the same Batch Executive that will be controlled from a graphic with embedded Batch Controls in another remote location.
On the new workstation in the remote location I can easily filter the batches to only show batches from the new AREA. However, I am struggling to make the main control room Batch Operator Interface only show batches from the first four AREAs.
The "DeltaV Batch Operator Interface - [BATCH LIST]" window has a "System Configuration and Defaults" dialog; however, the filter seems to only support wildcards with the % symbol. Unfortunately there is no pattern that matches only the first four AREAs and not the new fifth AREA. Is there any more intelligent ways to exclude an area from a console's batch interface?
