I have to extract alarm list for an old plant.
Can anyone let me know how to extract alarm properties (threshold of LOLO, LO, HI, HIHI and status if those alarms are enabled or not) of AI block or PID block from DeltaV explorer?
Hi Junggyu, you will need to use the User Defined export utility to export a list of control modules using a custom format specification.
You can specify many module parameters in the speciation file, including thresholds and enable status.
Hope that helps.
Hi Junggyu,
To create a new format specification if one is not available, follow these steps;
