We have a class that has three External Reference parameters: DEVICE_STATUS1, DEVICE_STATUS2, and FAULT_STATUS.
I generated a format file for this class that has all fields selected. When I perform a User Defined Export on an instance of this class, the DEVICE_STATUS1 and DEVICE_STATUS2 parameters will export the values as PASS_STATUS no matter what the actual parameter value is. The FAULT_STATUS parameter value will be exported just fine though. I tried changing the names of the DEVICE_STATUS parameters to something else, regenerated the format file, and the export worked fine. I am wondering if DEVICE_STATUS is some kind of DeltaV keyword that is preventing my two parameters that begin with DEVICE_STATUS from being exported properly. Has anybody seen behavior like this before?
See images below for reference.
Steven
