I am using custom format file to create new module instances of a class based CM. I am able to create new CM modules using import function if I set the Area parameter path to an Area, PC, or Unit. However, I would like to assign/bind the new CM to an existing EM for each instance. I have added a new CM class to the EM class and am able to bind the new CM to the EM at the instance level manually in DV Explorer. However, when I try to set the Area path to the EM in the import file I get the below error message.
My question is, can bulk edit be used to bind a module block instance and if so how?
1: WARNING: The name 'Module Name' was not found in this context2: WARNING: Unable to get named module
Colton
