We are trying to customize a DeltaV InSight report and need to have a filter in the Excel Template (.XLTX) that is populated by an HML file to create the report as an Excel Workbook (.XLT). We can write the filter in the Workbook but not in the Template. We need the filter in the Template so it will automatically generate with the desired information.
An example of the filter in a Workbook is shown in the attached file. A InSight Overview Template (zipped) is also attached.
Google says this can't be done but I'll bet one (or more) of you can figure it out! Thanks in advance!
Template_Filter Picture.docxOverviewTemplate_20210521.zip
In reply to James Beall:
In reply to RobPerry:
TemplateOutput.xlsxAreaPerformanceTemplate - Copy1.zipArea Performance Report - Copy_xsd.zipMore info:
Running the InSight Reports doesn’t export a raw xml, but it looks like it directly imports the xml into the workbook.
Attached is the excel template (Area Performance template provided in DeltaV/DVData/InSight/Reports/Templates/AreaPerformanceTemplate-Copy1.xltx) with it’s xsd definition. The ultimate goal is to show the rows in the table that have %Time exceed their % Time Limits. We could achieve this by either (1) filtering the rows by the red color text that shows up in Columns W, X, Y, Z, AC, or AD because there is Conditional Formatting rules applied to them, or (2) filter the rows with the binary equation output in column V (I wrote a very simple equation for now for testing purposes). Either goal is desired, and ultimately we want to be able to filter this without human intervention of some kind (i.e. pushing a button that runs a macro that will filter the rows in the table).
With (1), I’ve ran into problems with the template; first off, the template grays out the “Filter by Color”, and it only show “Text Filters” versus “Number Filters”. With (2), whenever you run the Performance Reports on InSight for the report output (i.e. TemplateOutput.xlsx), the result does not show up properly. You have to un-filter and filter Column V again for the results to show up properly, which still involves human intervention still.
