Hello All
I was trying to import our Latest database configuration backup taken from the proplus (taken from backup option of DV database Administration ) on our DeltaV Laptop from Restore option available in DV database Administration. Both the Proplus and the DeltaV laptop have the same deltav versions 11.3.1.
I encountered the following issues:
1. Initially the restore utility in DV database Administration kept on giving an error of folder path mismatch,
this issue was resolved by creating and keeping the backup under the same folder path in the destination machine as the folder path where the backup was created in the original Proplus machine, has anyone else also encountered this? Any other fix or workaround?
2. On opening the DeltaV explorer after restoring the database, the proplus name in the restored database is different than the laptop , it is the name of the machine from where the backup was taken, When I try to create a proplus or re run the workstation configuration again, it fails giving an error with message saying, "rename the workstation to match the proplus name in the import file". Has any one else also experienced this, Any solution or work around?
Waiting for any feedback or help
Thanks
DS
In reply to Andre Dicaire:
