VM Server Deltav Primary and Secondary bad status
I have DeltaV installed on a VM server where the ProPlus diagnostics shows Overall Integrity as BAD. Primary and Secondary communication BAD.
I am trying to get Batch Application manager working on this system but I think this bad communication is causing problem.
Not sure if this is physical cable problem or am i missing any setting here. Any help would be great. TIA
  • Was this working before? When did it stop working? What was the last major change?
    Can you ping from ProPlus to other nodes?
  • In reply to Lun.Raznik:
    This is the newly set up VM. so Batch Executive never communicated with DeltaV ever. when I do TCP/IP Ping from diagnostics it does successfully.
  • In reply to Rucha Bhagwat:
    Can you please check if the virtual NIC not reversed? Thus say, Primary on ProPlus is connected to Secondary on Batch Executive. Can you also share what virtualization tool/solution are you using? (Hyper-V, VMware, VirtualBox, etc).
    I am using Hyper V (VM). Not sure about the NIC reversal
    Are you using DVS? If yes, what version?
    If not, what host OS are you using?
    On the ProPlus, can open cmd.exe and do a ping to the target node?
    For example,
    ping <10.4.0.10>
    Change <10.4.0.10> with the IP of the target node.
    Well coming to the specific problem when I load the UP in BOI it get to READY state and when I try to run it gives me error "Cannot Communicate to phase logic (unsol)" have never seen this. I am though able to run phase from the unit externally.
    I would recommend to focus on getting at least one network interface in a good state.
    And if you can provide answers to my query above, we might be able to identify the issue.
