I have DeltaV installed on a VM server where the ProPlus diagnostics shows Overall Integrity as BAD. Primary and Secondary communication BAD.
I am trying to get Batch Application manager working on this system but I think this bad communication is causing problem.
Not sure if this is physical cable problem or am i missing any setting here. Any help would be great. TIA
In reply to Lun.Raznik:
In reply to Rucha Bhagwat:
Are you using DVS? If yes, what version?
If not, what host OS are you using?
On the ProPlus, can open cmd.exe and do a ping to the target node?
For example,
ping <10.4.0.10>
Change <10.4.0.10> with the IP of the target node.
