Hi Emerson Community.
Had a quick question- We recently installed a new Op DeltaV Station as the old one had reached end of life. After setting it all up, everything seems to be working ok minus one issue.
I've noticed on the new op station, each time we try to connect to the Batch Operator Interface (from the link on Operate's Toolbar), it always asks to select the Executive node from a drop down as 'no executive node was found for this machine'.
Our Batch Exec is present in the drop down so once I select it and hit ok, it connects without any issues. But it is sort of a headache. Not to mention it doesn't do this for the other Op Stations (ones that were not replaced).
I am not really sure of how to make it stay connected such that when you click on the BOI icon, it doesn't pull up this 'Select Batch Executive' drop down each time you go to a different screen and then need to come back to the BOI. This happens even if you are logged in as the superuser.
I have attached a picture below. Running rev13.3.1
Thanks in advance!
In reply to Scott Thompson:
