I recently downloaded a batch executive on a long time running live system. The batch exec gave me the following error:
========== Verification for OPK_SETUP ==========
Expression Check: PASSED
Equipment check: PASSED
Formulas check: PASSED
Link Groups check: PASSED
----- Checks specific to Workstation, APP_BEXEC2 -----
Algorithm check: FAILED
Transition 'T9' does not have at least one preceding Step.
Step Associations check: PASSED
As this operation had been run multiple times previously with no error and no changes had been applied in the last 6 years, I proceeded with the downloaded anyway option.
The T9 referenced is the transition from a final phase at the end of a single branch. It should be a termination rather than a transition.
I am just wondering if the transition block rather than a termination block has any potential impact in the operation and higher level unit procedure. I'm guessing not seeing as it has not been noted in the last 7 years. Is there a merit to modifying the operation design?
Thanks for any input.
In my experience, such warnings always are right in some way.
You do not give enough information to have an idea what the cause is.
The message suggests that T9 is not linked to a preceding step. You do not indicate you checked a connection between a step and T9.
If T9 is a termination, why not change it from a transition to a termination?
