'DbsModule' error while deleting modules
I'm receiving the following error while deleting modules.
An error occurred.
Reason:
DATABASE INTERNAL ERROR: Attempt to use an instance of class 'DbsModule' as an instance of class 'DbsModuleInstance'
Details:
1: DATABASE INTERNAL ERROR: Attempt to use an instance of class 'DbsModule' as an instance of class 'DbsModuleInstance'
2: DATABASE INTERNAL ERROR: Unable to set resolved module tag for module block
Can anyone share with me what causes this error?
Charlie
  • Hi
    while deleting modules above errors come means these modules are having some references to the other modules or class for that module is usefull somewhere else so first remove the references for that module , and you can delete the modules .
    if the modules are class based then you can first do the module class less and then delete the modules .
    Regards
    Prashant
