Trying to understand how to completely remove a Device tag and related control module from our system.
Removing one DI loop that is a conductivity alarm for a pump that was replaced
Hi, You can go to respective controller and browse your module in "assigned modules". Once you find your module right click shows you "delete assignment" after that again right click the module, navigate to download there you can see delete module, do that and its done. To delete channel assignment, you can name it to spare then disable the channel if you want to., Before all these I would say you right click the module from the area and check for references.
In reply to Neeraj S:
