Hello everyone
First a little context:
I am new to deltav and was asked to develop a HMI for a simple process, but the deltav operate misbehaves. When I try to run a figure it says there's a compile error in a hidden module FRSI_glb, then "error number 91 (5B) Object variable or With block variable not set". I've tried to solve it without success. Apparently, a previous user did something to the main files, saved, and now the errors come out everytime I switch to run mode.
Now the real question:
Is there a way to restore only the configuration of deltav operate without compromising the setup of control network and every other software component of the deltav suite? Doing this I hope the main picture of deltav operate goes back to normal.
Many thanks in advance.
In reply to Matt Stoner:
