How do I configure a PIN (Pulse Input) function block for shaft RPM.
Dave Grubwieser
9 Aug 2024 4:20 PM
Senthilkrishnan M
31 Jul 2024 3:15 PM
31 Jul 2024 11:26 AM
Adding device to Event Chronicle
Tyler-Bolick
25 Jul 2024 6:01 PM
Dynamically adjusting Span of Control on OWS
Rishi
24 Jul 2024 6:49 AM
Licenses
DI as Pulse Input (PIN) for belt speed
deriving a flow rate from a pulsed input - is the Pulsed input function block the right block for this application?
Timed Pulse Function Block
Turbine Flowmeter Pulse Input to DeltaV
How do I wire pulse device to a Series 2 Multifunction I/O Card installed in backplane as card #5 with an MDPlus controller.
The pulse generator is a CAT magnetic speed pick up generating up to 2500HZ, voltage of 12Vac across its terminals. Do I wire this directly to the multifunction card via an SD32 barrier just like that? I have one speed sensor wired this way to terminals 25/26 of the I/O card but it seems not to record any frequency at the DCS. Please help.
