How do I configure a PIN (Pulse Input) function block for shaft RPM.
Jesse Delanoy
15 Aug 2024 10:50 PM
DeltaV Objectivity Database Limitations - Number of Class-Based Control Modules / DB Size and Performance
13 Aug 2024 6:02 PM
Process History View, Set Y Scale grayed out
Rishi
13 Aug 2024 3:29 PM
CIOC Communications
GaryL
11 Aug 2024 1:29 PM
Stefan Muellner
9 Aug 2024 5:23 PM
DI as Pulse Input (PIN) for belt speed
deriving a flow rate from a pulsed input - is the Pulsed input function block the right block for this application?
Timed Pulse Function Block
Turbine Flowmeter Pulse Input to DeltaV
How do I wire pulse device to a Series 2 Multifunction I/O Card installed in backplane as card #5 with an MDPlus controller.
The pulse generator is a CAT magnetic speed pick up generating up to 2500HZ, voltage of 12Vac across its terminals. Do I wire this directly to the multifunction card via an SD32 barrier just like that? I have one speed sensor wired this way to terminals 25/26 of the I/O card but it seems not to record any frequency at the DCS. Please help.
