Based on space requirements a suggestion has been made to install the deltav controllers and cards on the floor of a panel (i.e. Run din rail along the base with carriers flat on the floor). Would this proposal require any extra considerations?
Thanks
I agree with all the other replies here and want to add a few things.
1. Installing on the bottom of the cabinet will void all hazardous area certifications.
2. While the hardware may work installed on the bottom of the cabinet it will mean that the temperatures in the electronics will be higher than when installed normally in a cabinet. Running electronics at higher temperature decreases the expected life of the electronics. See Effects of Heat and Airflow Inside an Enclosure Whitepaper for more information.
Best regards,
Rune
