HiI am having trouble with DeltaV Reporting Tool.System Layout:
Deltav 13.1Fully redundant system (except the engineering station I am working on, Only primary connection)Eng station is setup as simplex node in DeltaV explorer.Excel 2016Workstation has 3 NIC's Primary (Active), Secondary(Disabled), Plant LAN (Active)
I am receiving the following error when I try to retrieve data:
The IP address shown is a secondary network which this workstation does not have access to.
I have uninstalled the add-inRe ran workstation configDownloaded Workstation
At a bit of a loss as to how to correct this..
TIA
Chad.
