How to Enable/Load "DeltaV Reporter" Continuous Historian Excel Add-In via PowerShell Script
I have an Excel (32-bit) .xlsm document that has multiple Continuous Historian function calls using the DeltaV Reporter Excel Add-In. When I open the file directly in Excel, it works fine.
When I use a PowerShell script (.ps1) to open the file with Excel.Application calls, all the function calls give the error response "#NAME?". I've tried a long list of different things to get around this and I'm just running into the same brick wall each time.
If I leave a blank workbook open in Excel in the background, then the PowerShell script works. If Excel is not already running before the script opens the file, then the Excel Add-In doesn't load. (Note that the COM Add-In portion of the DeltaV Reporter does load automatically at startup of Excel, regardless. It's the Excel Add-In, ContinuousHistorianWF that doesn't load). See screenshot below of the two Add-Ins that load when I manually open Excel. The DeltaV Reporter COM Add-In still loads when the PowerShell script runs, but the other one doesn't.
I need this XLSM file to open periodically (I'm using Windows Task Scheduler to call the PowerShell script, but I'm open to other means), so that a computer from another domain can reference the refreshed values in the XLSM file on demand.
Here's the PS1 content:
# start Excel
$xl=New-Object -ComObject "Excel.Application"
$xl.DisplayAlerts = $FALSE
#open file
$filename = "\\APP\DVData\CondLoadoutAccuload.xlsm"
$wb=$xl.Workbooks.Open($filename)
$wb.Save()
$wb.Close()
$xl.Quit()
# now you only need to release two.
while([System.Runtime.Interopservices.Marshal]::ReleaseComObject($wb)){}
while([System.Runtime.Interopservices.Marshal]::ReleaseComObject($xl)){}
  • In my endless internet searches for PowerShell / Excel automation tips, I finally found the key to the issue. By design, Microsoft does not enable the Excel Add-Ins when Excel is run programmatically. If I open Excel directly, myself, the Add-Ins are active, but since it's my PowerShell script opening the Excel application, only the COM Add-Ins are loading automatically. I found the code needed for the DeltaV Continuous Historian Excel Add-In to load...
    After the application has been opened, add these two lines of code:
    $xl.AddIns.Item("DeltaV Continuous Historian Excel Add-In").Installed = $FALSE
    $xl.AddIns.Item("DeltaV Continuous Historian Excel Add-In").Installed = $true
    where xl is the name of the ComObject "Excel.Application"
    I hope this helps someone else, because it was very frustrating for me to find it, as a newbie to PowerShell and .NET coding.
