errors while performing station configuration on deltav 10.3.1 for historian workstation
Tom Light
14 Jun 2024 5:27 PM
little experience with profibus communicating with Delta V I need some assistance
Rishi
9 Jun 2024 10:19 AM
Licenses
William Duncan
6 Jun 2024 5:59 PM
Deltas
Daniel Moyers
5 Jun 2024 8:50 PM
GEM Timer Script not running
Hendrik Botha
4 Jun 2024 7:28 AM
Installation of EG WorkstationST on DeltaV App station
Getting an error while trying to Restore Continuous Historian Administrator
Historian in non-Deltav workstation
DeltaV Workstation Configuration Receiving Domain Error Prompt...CNTSecurity::IsDomainAdministrator::Failed!A Domain Controller Could not be Contacted
Error while downloading
The Historian workstation (Dell Precision T3500) crashed at site.
Hence re-installed Windows XP Professional with Service Pack 3 in the same machine.
Logged into Windows in Administrator mode, created windows password for administrator user and also increased the virtual memory.
Then installed DeltaV v10.3.1
Did PCinstall using station configuration file. However the following errors were generated during
File Security
stage of PCinstall :-
CService Utils::InstallCSharpService. The service handle didn’t open. Error 1060
An error occurred while installing Guardian Services. Try rebooting your computer or see your administrator for an explanation of error. The operation completed successfully.
This is a Windows Vista workstation. Version control can only be installed on a server machine. The operation completed successfully.
Also while downloading this workstation from Explorer in Engineering Station; the download will stop at 98%. The error message is that the node is turned off. Hence not able to connect this historian workstation to the existing DeltaV network.
Neil Castro
6 Oct 2017 12:27 AM
Did you encounter any warnings or errors when installing DeltaV?
You may want to double check the PCInstall dialogs if install SQL is ticked. The install may show errors since full SQL is not compatible to workstation OS like XP.
Jithu Akkara
9 Oct 2017 8:27 AM
Neil Castro
SQL option was not ticked.
The following errors popped up during "File Security" stage of PCinstall :
1. CService Utils::InstallCSharpService. The service handle didn’t open. Error 1060
2. An error occurred while installing Guardian Services. Try rebooting your computer or see your administrator for an explanation of error. The operation completed successfully.
3. This is a Windows Vista workstation. Version control can only be installed on a server machine. The operation completed successfully.
Neil Castro
12 Oct 2017 3:55 AM
Jithu Akkara
Have you tried checking the UAC? I Do not have v10.3.1 documentation but double check if XP SP3 is supported. If my memory serves me right. I usually install DeltaV using XP SP1 and let DeltaV install complain if it needs an OS with higher SP.
Did you install XP 32bit or 64bit?
