Hello,
I want to put a workstation on my control Network after restoring the image.I restored the image. Created a Node in DeltaV Explorer "Control Network".Assigned Professional Station license to that Node,Assigned Areas.Created Computer Name in my Active Directory of Domain Controller under DeltaV Workstation.Exported Configuration File.I joined the system on Domain.After this I ran workstation Config utility and imported Config file.While Config Utility I prompted a error which is attached. A domain Controller could not contacted in mid of Utility processing During "Creating User accounts.I was logged in as domain Administrator on workstation during this activity and System was on Domain Network.
If i press OK the prompt Utility Starts further process and Finish the Installation.For Operator Station It works.
DeltaV Version:12.3
Domain: Server2008
But for Professional Station ,DeltaV Explorer Opens for 2 Hrs Only and after that I received Database Access Denied.Though DeltaVAdmin password is same on P PLUS and Workstation.But after some time DeltaV Explorer again opens but I am not able to download any thing from Workstation."Professional Station. Unfortunately I am at site and dnt have telephonic access.Your prompt response will be Highly appreciated
Best Regards,
AK
In reply to Steve Linehan:
Thanks Steve, for your reply.I did same steps which you mentioned,First I Put the system on WORKGROUP, then Network and after that joined the domain.How can I clear Previous AD logs after restoring the image on domain Client.My second problem still exists.Database access denied for some time on same station.But after few Hours Access available for few Hrs,But not able to download from workstation.
In reply to AK:
In reply to bilal761:
