DTE TE_TIME_STR changed on Daylight Saving change
We have a few totalizers for production which are setup to trigger at 07:00 (TE_TIME_STR setup) with an interval of different hours.
These totalizers have been programmed this summer.
Everything was working fine until the last daylight saving change, where they changed to 06:00.
The reports were then triggered at 06:00 instead of 07:00. We had to change the TE_TIME_STR back to 07:00.
Why is it when the daylight saving rolled back one hour to normal time, the DTE time also rolled back one hour?
Pierre.
  • Pierre -
    This is a known / expected behavior of the DTE block when TE_TIME_STR and INTERVAL_STR are configured. The DTE references local time. In order to maintain the configured INTERVAL_STR, the block shifts TE_TIME_STR by the same amount as the local time has been shifted.
    You can workaround this by adding a CALC block that reads the current date and time, extracts out the date portion, and then appends the "T07:00:00" to the date. Write this last to the TE_TIME_STR of the DTE block, and you have effectively hard-coded the 7AM.
    If you have Guardian access, there is a KBA describing this behavior, and the workaround, in detail.
    Regards.
    Ray
    Thanks a million to all. I'll have a look and will fix it.
    Pierre
