Hello All,In DeltaV Live, on clicking the Key F12, the debug window opens as seen below.Under the Sources Tab , we can see the Typescript for the active display and can also change it.
However, when I click 'Ctrl+S' the _events tan has an exclamation mark that says the changes are not saved.
Is there a way that the changes in Debug window can be temporarily saved to help the debugging?
Don't which the change to be permanent in the display.
This can save time in updating the display in Graphics studio, saving and publishing to check if a code works.
Regards,Navin Singh
