Deltav 9.3 Module Being updated by administrator
Hi its regarding deltav9.3 we are not able to open one module and the error says " module is being updated by admin in proplus"
1.Tried restarting the system.
2.Tried to login with different usernames.
3.Database connections were disconnected.
4.Killed cs.exe in task manager.
5.Expaort and import was done
I ahve tried these any more suggestion ???
  • Have you cleaned the db?
    Last ditch effort, copy the module, unassign and remove the original from controller, then rename the copy , assign and download.
    I even did extended clean of db.
    i cannot unassign or edit that module, when i try doing that error pops that its been updated.
  • Did you try downloading setup data to the ProPlus and also to the node that the module is currently running in?
