I am trying to build dynamic references within an EM to a CM on another controller. Setting up the PV, alarm limit etc are all fine but I am having trouble setting up a dynamic reference to the alarm enable parameter.
Normally if I was using aliases then it would just be //#MODULE#/HI_HI_ALM.ENAB' so to build a dynamic using the alias that would just be '^/DYNAMIC_PARAMETER.$REF' := "//#MODULE#/HI_HI_ALM.ENAB"; however using this I am not able to enable/disable through the dynamic. Is there another way I should be building my dynamic?
In reply to Matt Stoner:
