I would like to print out a graphic each day at a specified time. I am using the scheduler to print the current graphic and this works fine. Once I add logic to change the graphic to my desired graphic, the print command fails. Here's what I'm using now:
frszexpertreplacepic 4, "graphic_name.grf"
sendkeys "{ENTER}", false
printmaingraphic, me
I do know that if I use only the last two lines, the print is successful. Not sure why the replace picture command is causing issues.
In reply to Matt Stoner:
In reply to jasonbum:
