Printing in deltaV
Printing in deltav
Usually the operator interface background is gray. How can change the background to white in printing? for example writing script to change the background when push the printing button on tool bar to save the printer toner (only change the background in Hardcopy).
  • There was a KBA published in 2002 describing how to do this.  If the link below doesn't work, lookup "AUS1-110-020114084027" on the Foundation Support Site.
    http://www3.emersonprocess.com/Systems/Support/documentation/deltav/kba/AUS1-110-020114084027/carticle.asp?qsproductlineid=2
    From:        "mohsen" <bounce-mohsen@community.emerson.com>
    To:        <DeltaV@community.emerson.com>
    Date:        10/17/2012 10:31 AM
    Subject:        [EE365 DeltaV Track] Printing in deltaV
    Printing in deltav
  • In reply to Michael Moody:
    Private Sub bmpPrintMain_Click()
    On Error GoTo ErrorHandler
       'frsPrintMainPicture pn_MyMonitor.CurrentValue
       Dim strDefColor As String
       Dim strPicName As String
       Dim curObj As Object
       If pn_MyMonitor.CurrentValue = 2 Then
           strPicName = frsVariables.gs_mainCurrent2.CurrentValue
       Else
           strPicName = frsVariables.gs_mainCurrent.CurrentValue
       End If
       If frsObjExists(strPicName, , curObj) Then
           strDefColor = curObj.BackgroundColor
           curObj.Parent.ActiveWindow.Active = True
           curObj.BackgroundColor = vbWhite
           'SendKeys "{Enter}", False
           Application.ActiveDocument.Printout
           curObj.BackgroundColor = strDefColor
       End If
    Exit Sub
    ErrorHandler:
       HandleError
    End Sub
    I did not access to foundation  support , can you send document?
