When I try to start DeltaV Operate Run, the progress bar stops at 14 % and the following error message appears:
" Error Number: 0 (00000000) A compile error was detected in a script that was about to run. The script will not be started"
I copied over backup files for the Pic folder in the Graphics-iFix directory last week and that temporarily fixed the problem; the program would run. However, on subsequent attempts at starting the program up, the same error message appeared and I had to copy and replace the files again.
Does anyone have an idea why this is happening?
Nikolaspf
In reply to bhushan619:
I believe that Standard\UserSettings.grf or Standard\ComputerName_Settings.grf is the script running when at 14% but Error 0 isn't an error.
I have only seen Error 0 when an Exit Sub is missing before the Error handling logic (See highlight example below)
You may also have logic that is called in Usersettings Initialize script that is missing the Exit Sub. Go thru whole script and check each thing that is called as well.
Matt
In reply to Matt Stoner:
In reply to nikolaspf:
In reply to johnjt:
Best Regards,
