Folks,
DeltaV 12.3 Service Pack 1 & DeltaV_123_WS_05_CSS have both recently been released. Which one do I apply first? Does one supercede the other?
Rod
DeltaV_123_WS_05_CSS is a hotfix for 12.3 so you do not need it if you are installing Service Pack 1.
In the previous releases, each version e.g. v11.3 and 11.3.1 had seperate hot fixes. Hot fixes are usually applied at the last after DeltaV is installed and licensing requirement is met.
