I am in the process of resurrecting a single control single workstation system (DeltaV v. 12.3). This system was working fine before it was powered down about 1.5 years ago. I recently powered it back up and was presented an error from the Easy Security Management App that it had stopped working. This window popped up continuously as I tried to navigate through DeltaV explorer. I found out that this software isn't necessary to run DeltaV and that it will sometimes lock down ports (like our USB dongle with our license) so I removed it and rebooted the computer.
However I'm still being presented with an "Access is denied" message when I start DeltaV explorer. Also when I try to get a license report I get an error message saying "Access is denied". I can't download, I can't commission anything... please help!
Here is what I have tried so far:
1. I uninstalled Easy Security Management App.
2. I have rebooted several times.
3. I have installed the USB dongle in a different port.
4. I have tried loading our license file on top of our existing license file from the CD that came with the software.
Can anyone suggest anything else?
Thanks!
Kevin
Not sure what the actual problem is, but if Easy Security had the USB ports locked down then uninstalling Easy Security would not necessarily unlock the USB ports. If you're not sure, you should probably install Easy Security and verify that everything is off and then uninstall it. That being said, I don't think Easy Security interferes with the license dongle even when it has the USB ports locked down so it’s probably not the source of your current problems. Are you logged in as an administrator when starting DeltaV Explorer? In DeltaV Explorer, if you open the Help Menu/ About DeltaV Explorer, does the System ID show a key? Does the key match the loaded license file(s)?
In reply to Steve Linehan:
In reply to ksupak:
