I am trying to verify parameters in all of the AI & PID function blocks.
The DV Export utility does not have this feature from what I know.
Is there a way to export these parameter values within DeltaV or some external application into a CSV file?.
You can export module function block parameters using bulk export. You cannot just ask for all AI and PID function blocks, however.
You can create a format specification file that includes AI1/parameters AI2/parameters etc.. PID1/parameters, PID2/parameters etc...
Then select all modules in you control strategies and bulk export against your new fmt file. Any modules that do not have an AIn or PIDn function block will return <NULL>.
In excel, you can then filter on modules where the columns for AIn and PIDn are not <NULL>.
For runtime data you may use DeltaV Excel Addin (DA access portion) to pull data.
