I created a new color table (Theme_Colors) under User, because I would like to customize the color table. So far everything works perfectly, I can change a color in the color table and see the color change at run time. However while I'm in DV Operate Configure the color I changed in the table doesn't update, even after closing the DVOC and re-opening the pictures. The only way I have found to "update" the objects color in configure after changing it in the color table, is to dig into its animation properties, click on the effected component, (Foreground or Edge), then hit "OK" without changing a thing. At this point the object's color will update. Of course doing this for each object on every picture is way to time consuming. Is there a way to simply refresh the picture to update the color reference?
