Hi, I am trying to validate a tag with Electronic Signature by using the ValidateSignatureAndWriteValue Method. I copied the example in the Automation Interfaces Help into the script of a Button in the graphics, but it did not work. It only pop up the message "Signature is not enabled on this node". I don't know which node did it refered to.
I am pretty sure that the node where the tag is assigned to is ES enabled because I am able to validate the ES when using the faceplate.
Thanks for help in advance.
Regards
Fooss
You have to enable electronic signatures in system preferences, then configure it for the system under "setup.. electronic signatures" in deltav explorer. See: http://socialkb.suite-sol.com/home/Emerson/DeltaV/Reduced_NEW_MasterBOL.ditamapExport-no-eps/Reduced_NEW_MasterBOL.ditamap?nav=x-19105#file267-c_configuring_electronic_signatures http://socialkb.suite-sol.com/home/Emerson/DeltaV/Reduced_NEW_MasterBOL.ditamapExport-no-eps/Reduced_NEW_MasterBOL.ditamap?nav=x-20106#file263-c_electronic_signature_properties fooss <bounce-fooss@community.emerson.com> wrote:
Thanks Yousseff. I have already done that. I could validate the ES in DeltaV Operate, so I do believe that the node is already ES enabled. Just that, I dont know which node is the VBA referred to when it is executed.
In reply to fooss:
Be careful, you also have to enable electronic signatures for each area. Right-click on an area in DeltaV Explorer and you need to tick a checkbox.
I am not familiar with how VBA uses them, though.
In reply to István Orbán:
Thanks Istvan, I have also enable the ES for each area.
Anyway, I have managed to get the VBA working by using the DeltaV_ESig Class instead of the ESignature showned in the example.(I still dont understand why the ESignature Class dont work).
Now, I would like to find out where to get the information/writeup for the 4 methods available in the DeltaV_Esig class ie. GetSignatureAndWriteValue, SignatureRequirement, ValidateSignature and ValidateSignatureAndWriteValue. There is no HELP for these methods in the VBA Editor.
In short, please help to find out these 2 questions..
(1) Where to find the writeup for the methods used in the DeltaV_ESig Class?
(2) Which library should I referenced to to get the ESignature Class working?
Thanks.
