I'm looking for a manner to start the generation of a standard FHX file from a command line, ie, in a BAT file.I would like to export a FHX file of the whole "Control Strategies" item from a Shell command, not from DvExplorer menu.Is it possible ... and how ?
I have tested all the 'c:\deltav\bin' files with the syntax "TheFile /?" to try finding a shell command with no success.May be with a DLL library file ? I don't know.
Thanks, Jack
You can't export just the Control Strategies but you can export the entire database with two different command lines using DBImpExpClient (located under DeltaV\bin directory):
1. DBImpExpClient.exe -e [DatabaseName] Filename.fhx
Example: C:\DeltaV\bin\>dbImpExpClient.exe -e DeltaV_System D:\ExportTest.fhx
2. DBImpExpClient.exe –de [directory path]
Example: C:\DeltaV\bin\>dbImpExpClient.exe -de C:\
The exported database file will have the database name appended by the current date, for example: DeltaV_System_Oct08.fhx
In reply to Matt Stoner:
(3 days to find the way to post a reply to this forum, lol.)
Thanx a lot, Matt.
Is there a documentation about these syntaxes ?
In reply to Jack_France:
If you have Guardian Support you can probably find more information that way but Books On-Line doesn't have any information on it.
Typically you can put /? at the end of executables (i.e. DBImpExpClient /?) and it will document all the command switches available but it doesn't work.
I have talked with some people in Product Development about this issue but I assume it won't be fixed anytime real soon.
Regards
