How to create a standard FHX file from a Shell command line ?
I'm looking for a manner to start the generation of a standard FHX file from a command line, ie, in a BAT file.
I would like to export a FHX file of the whole "Control Strategies" item from a Shell command, not from DvExplorer menu.
Is it possible ... and how ?
I have tested all the 'c:\deltav\bin' files with the syntax "TheFile /?" to try finding a shell command with no success.
May be with a DLL library file ? I don't know.
Thanks, Jack
  • You can't export just the Control Strategies but you can export the entire database with two different command lines using DBImpExpClient (located under DeltaV\bin directory):
    1. DBImpExpClient.exe -e [DatabaseName] Filename.fhx
    Example: C:\DeltaV\bin\>dbImpExpClient.exe -e DeltaV_System D:\ExportTest.fhx
    2. DBImpExpClient.exe –de [directory path]
    Example: C:\DeltaV\bin\>dbImpExpClient.exe -de C:\
    The exported database file will have the database name appended by the current date, for example: DeltaV_System_Oct08.fhx
