Set visibility based on DeltaV Live Theme
Do we have a way to know which theme is selected in DeltaV Live and set the visibility of an element accordingly?
  • Not sure what the use case is for visibility based on a theme but you can have a Library Standard change it's value based on the theme selected.
    Select the Library Standard and on the right side Graphics Configuration window you can see the default value and then the table below shows all the themes and their associated value you can set (default being nothing entered and always uses the default).
