Hi All,
I have a DataLink that I am trying to set the Visibility from VBA when a timer is greater that 0. This particular case requires it to be set by VBA. I would normally I am trying to set the visibility condition to this DVSYS.MY_TIMER/TMR1/TM_PV.F_CV > 0.
I am having trouble finding this property of the object? (obj.Source.Visibility)?
In reply to Cedric Dawnhawk:
In addition/alternative I would suggest adding If before setting the source: If Not objVisible Is Nothing Then End If If you don't have the If and it can't find an object, you will get a VB Error when trying to set the source. You can also name the visibility animation and search for this directly: Dim objVisible As Object Set objVisible = FindLocalObject(Me, "avRect32") If Not objVisible Is Nothing Then objVisible.Source "DVSYS.TEST_MOD/TMR1/ELAPSED_TIMER.F_CV > 3" End If Just be aware that if you copy the object and use it elsewhere that the name is auto generated and may affect the logic. If you have a lot of instances where you are setting sources of the object, you might want to search for the object name and set an object for that and then use that object to search for the local names. Set objDynamo = Nothing Set objDynamo= frsFindLocObj(Me, "Rect32") If (Not objDynamo Is Nothing) Then Set objVisible = FindLocalObject(objdynamo, "avRect32") If Not objVisible Is Nothing Then objVisible.Source "DVSYS.TEST_MOD/TMR1/ELAPSED_TIMER.F_CV > 3" End If 'Do other source finding/setting using the objDynamo object End If
