Does anyone know what security key is required for access to the Live menu bar "display set" selection list?
I have a training station that is being utilized by multiple departments, and would like to allow each department to select the appropriate display set for their respective area when training. What I'm finding is the training user accounts do not have the "Display Sets" menu bar option available, but an administrator level account does. I cannot find anything in BOL documenting what key is required to enable this option. Rather than fiddling around trying different keys, I was hoping someone could point me in the right direction. If a high level of access is required for this option is there a way to change this?
Hi Jesse,
You are correct. There is a security key to allow users to switch Display Sets. You can find it in DeltaV Explorer, under Setup/Security/Function Security:
As you can see, there are several keys that allow you to have granular control over multiple aspects of the DeltaV Live HMI. In Books Online you can find these under Locks assigned to functions. Depending on your strategy for user access, you could modify your groups or individual users from DeltaV User Manager to assign the proper locks.
I hope this helps!
Camilo Fadul
Camilo Fadul | DeltaV Solution Marketing Director
https://www.linkedin.com/in/cfadul
